Build for casual gaming, help!
10 minutes ago, Scott Macbeth said:Hi guys, planning a build for a friend who mainly plays fortnite and casual stuff in that ball park. Budget is £1000 GBP, must include a monitor and may have to consider buying OS but for now lets ignore that. Any more questions please fire away I'm good at building the pc's but not the best at picking the right parts if you guys can help out, also i'm in the UK. All help appreciated.
Just buy this CPU cooler later, it's the cheapest dual tower cooler, also add a 2TB hard drive down the line maybe.
https://uk.pcpartpicker.com/product/r3xfrH/arctic-cooling-cpu-cooler-ucacop0900csb01
If you want a more compact case get a Q300L or Q500L, airflow is meh, but they are neat.
You may need to flash the bios with a USB flash drive
You can get a windows 10 key for $5 on ebay, or just install it and use it without a key, all you get is a tiny watermark.
If you find some 3600mhz CL16 memory go for that instead if it's not much more, might be able to overclock that 3200mhz kit anyways.
also double check reviews for that monitor, and 1080p 144hz free-sync display should be fine though.
You could just get a used RX 470-580 on ebay for really cheap and it'll run fortnite and stuff just fine at 100+ fps.
PCPartPicker Part List: https://uk.pcpartpicker.com/list/9qTYHB
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (£174.78 @ Aria PC)
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard (£77.98 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (£66.78 @ Aria PC)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive (£59.99 @ Amazon UK)
Video Card: Sapphire Radeon RX 5700 8 GB PULSE Video Card (£343.19 @ CCL Computers)
Case: Cooler Master MasterBox MB511 ATX Mid Tower Case (£44.95 @ Amazon UK)
Power Supply: be quiet! Pure Power 11 CM 600 W 80+ Gold Certified Semi-modular ATX Power Supply (£75.18 @ Aria PC)
Monitor: LG 24GL600F-B 23.6" 1920x1080 144 Hz Monitor (£139.99 @ Overclockers.co.uk)
Total: £982.84
