Here's the specs before hand.
MSI Z390 Godlike MB
i7-9700k
32gb ram (gskill Trident z)
Rtx 2080 ti
2X - Samsung 860 qvo sata (Raid 0)
2X - Samsung 970 Evo m.2 (Raid 0)
10gtek pcie nic sfp+
I'm having a weird issue with my m.2.  For some reason if I have the nic (or anything else I tested) plugged into the 3rd pcie slot the 2nd m.2 won't read and I'll get an m.2 genie error from msi bios.
IMG_20191107_022434.thumb.jpg.66c9e819a16b5f386b9db8c55eee3e09.jpgIMG_20191107_022531.thumb.jpg.0079e23f4280d7c62350a0fc0d396ed1.jpgIMG_20191107_022506.thumb.jpg.85bb03a3671f466e2acaf4396276da9e.jpg
If I remove it, it'll boot just fine.
IMG_20191107_022111.thumb.jpg.2e048f39ae1b5a4d74d98387dbafdf75.jpgIMG_20191107_022253.thumb.jpg.3bda64505ab2a97d53d98c1a459855c1.jpgIMG_20191107_022339.thumb.jpg.52b04afb2ffb5e04f8aedbc5c97c6549.jpg
Graphics card is in the 2nd slot and nothing is in the 1st or 4th slots.  Everything worked fine before I installed the 2nd m.2.  Only thing I could think of is the processor not having enough lane support?  Though that should only affect bandwidth ??‍♂️
https://linustechtips.com/topic/1121308-m2-pcie-issue/
