I flip PCs to make some money and I just got a Sapphire Nitro+ RX 480 4GB in the mail. I would like tot test it but I don't have a PSU to go with it in the pc yet. All I have right now is a 300W PSU for testing. If I run the card using only the PCIe slot for power just to see if I can get to the BIOS would it damage my card?
https://linustechtips.com/topic/1120689-test-gpu-without-6pin/
chances are you would never get into the bios the card would'nt fuction. last time i tried this, i was on a 1060, and it just didnt output anything
some radeon cards often would display a red message onscreen to:
Connect the 6pin cable to your graphics card
but that may have faded since last time i used a a radeon gpu
if you have the 300w psu, does'nt it have 6pin?
https://linustechtips.com/topic/1120689-test-gpu-without-6pin/#findComment-13022535
