Hey guys I need to build a portable gaming desktop so I want to use mini ITX I think what I picked out should work I already have a Sapphire 7850 2gb card that I am going to use but I need to know if what i have picked out will work together and if i should change anything and if any thing is overkill and i could save money or need to change something to improve performance however I would like to stay in the price range for parts that I am already at these are the links to all of the parts i have picked out. Thanks everyone for your help. :)
Mother Board: http://www.newegg.ca/Product/Product.aspx?item=N82E16813130664
CPU: http://www.newegg.ca/Product/Product.aspx?item=N82E16819113356
CPU cooler: http://www.newegg.ca/Product/Product.aspx?item=N82E16835119091
Thermal Paste: http://www.newegg.ca/Product/Product.aspx?item=N82E16835100007
Case: http://www.newegg.ca/Product/Product.aspx?item=N82E16811112348
PSU: http://www.newegg.ca/Product/Product.aspx?item=N82E16817256085
Sata Drive: http://www.newegg.ca/Product/Product.aspx?item=N82E16822148321
https://linustechtips.com/topic/112045-need-help-on-build/
Why an APU if you're using a GPU?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498059
You picked an A10k but have a 7850,
Use Pcpartpicker.com instead to find your parts. Everything else is good, just get an Athlon chip instead of an APU. Spend a little more money on a Hyper 212 or something. The 212 paste that it comes with is plenty good, so you won't be needing to buy a tube of Thermal paste.
You don't need an installation kit either. Your motherboard should come with Sata cables, just buy a hard drive alone.
Error: 410
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498065
to improve performance, I would install some RAM
I don't know why, but just reading this part of the post made me laugh pretty hard. xD
But yeah, he's right, you forgot to pick out some RAM. Just get 8 GB 1600 MHz RAM at the cheapest price you can.
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498088
i think this is t he guy i told to come here, it should be said that the game he wants to play is Everquest Next Landmark and Everquest Next, which needs a fair whack of CPU grunt , i think the case definitly should be changed to something cheaper and easier to work with so he can get a better CPU
Processor: Intel core i7 930 @3.6  Mobo: Asus P6TSE  GPU: EVGA GTX 680 SC  RAM:12 GB G-skill Ripjaws 2133@1333  SSD: Intel 335 240gb  HDD: Seagate 500gb
Monitors: 2x Samsung 245B  Keyboard: Blackwidow Ultimate   Mouse: Zowie EC1 Evo   Mousepad: Goliathus Alpha  Headphones: MMX300  Case: Antec DF-85
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498215
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD Athlon II X4 750K 3.4GHz Quad-Core Processor  ($86.98 @ Newegg Canada)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($31.06 @ DirectCanada)
Motherboard:  Gigabyte GA-F2A88XN-WIFI Mini ITX FM2+ Motherboard  ($104.99 @ Memory Express)
Memory:  A-Data XPG V2 8GB (2 x 4GB) DDR3-1600 Memory  ($74.99 @ Newegg Canada)
Storage:  Crucial M500 120GB 2.5" Solid State Disk  ($93.25 @ Vuugo)
Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($64.79 @ DirectCanada)
Case:  BitFenix Prodigy (Black) Mini ITX Tower Case  ($74.99 @ NCIX)
Power Supply:  Corsair RM 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($128.59 @ Newegg Canada)
Total: $659.64
Different case but it allows for an SSD.
I included RAM.
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498233
Total: $659.64
I included RAM.
is there a way to get a faster CPU on that  even if you have to move to mATX and use like a FX6300
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498250
Thanks Guys yeah I emailed the newegg cart to myself but the ram i picked was out of stock so it didnt show up in the email so i forgot about it I did want the case because the handle is so convenient as i will be moving it often as for the cpu I head no idea it was an apu so thanks for letting me know about that. As for what I am using it for I will mostly be using it to play the latest games such as BF4, Titan fall ect. and I was also wondering if this would stay at reasonable temps considering how tightly packed in everthing would be with only one case fan
RAM: http://www.newegg.ca/Product/Product.aspx?item=N82E16820211770
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498263
ill just leave that here. ignore, i did this build for US, scroll down there is build for CA
CPU:  Intel Core i5-4570 3.2GHz Quad-Core Processor  ($179.99 @ Amazon)
CPU Cooler:  Cooler Master GeminII M4 58.4 CFM Sleeve Bearing CPU Cooler  ($32.99 @ Mwave)
Motherboard:  Gigabyte GA-H87N-WIFI(REV2.0) Mini ITX LGA1150 Motherboard  ($122.98 @ Newegg)
Memory:  Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  ($66.99 @ Microcenter)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ OutletPC)
Case:  Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case  ($34.99 @ Microcenter)
Power Supply:  XFX 550W 80+ Bronze Certified ATX Power Supply  ($49.99 @ NCIX US)
Total: $547.91
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-06 15:36 EST-0500)
Pretty sure he has enoug $$ since his apu costs 130, and he picked case for like 180 bucks LOL
No i am kidding, i am here to help. You really dont need 16 gb, but if you want, you can just buy cheaper 16gb 2x8 that is equally good. If you have only 1 itake fan and 1 exhaust fan, the ram will be fine.
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498269
GRRigger that is actually perfect man that has more CPU grunt than my PC sounds almost perfect added optical drive to your list because im sure he will need one
Optical Drive:  Samsung SH-224DB/BEBE DVD/CD Writer  ($16.98 @ OutletPC)
Total: $564.89
(Generated by PCPartPicker 2014-02-06 15:48 EST-0500)
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498343
I know it might sound stupid but will price for the build above that Eroda put together be the same when shipped to Canada Ontario. (where I live)
No. His build isn't applicable since it's from all US sites. A build in Canada will almost certainly use different parts.
Error: 410
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498408
Mobo has 15$ discount combo, so i said, why not, its 107$, pretty good deal then.
There is also elite 130, it only costs cuple bucks more... more airflow and more appealing. IDK. And also id add exhaust fan, or intake if its possible. Good for temps. Some cheap silent fans.
fail, lets do it again xD didnt miss by much tho :D will fix and edit
EDITED:
CPU:  Intel Core i5-4570S 2.9GHz Quad-Core Processor  ($211.98 @ Newegg Canada)
CPU Cooler:  Cooler Master GeminII M4 58.4 CFM Sleeve Bearing CPU Cooler  ($34.99 @ Memory Express)
Motherboard:  Gigabyte GA-H87N-WIFI Mini ITX LGA1150 Motherboard  ($114.99 @ Memory Express)
Memory:  Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory  ($69.99 @ Newegg Canada)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($64.99 @ DirectCanada)
Case:  Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case  ($30.00 @ Vuugo)
Power Supply:  XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ NCIX)
Total: $582.93
(Generated by PCPartPicker 2014-02-06 16:05 EST-0500)
The cpu has same turbo as non S version, but is cheaper, so i added it.
You can add drive and case fans if you want. I can check for em if you want.
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498410
these lists should be taken as a what is recomended to purchase not a buy now button, once you know kinda what you are looking for its possible to find better deals or make slight alterations for a very similar system
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498551
Just realized that i can't actually ship anything from amazon.com to canada except on some occasions which sucks because there prices are better on some items however I did go over all of your suggestions and found i could save $100 on newegg. Unfortunately I'm pretty deadset on the case just because i really like it and its convience but here is a new list ive come up with for the build.(I do also Have an optical drive just for got to metion that aswell) and thank you for all of your help guys I do really appreciate it. another question i have is if this system will stay at a reasonable temp when gaming. Thanks :)
Mother Board http://www.newegg.ca/Product/Product.aspx?item=N82E16813130664
RAM http://www.newegg.ca/Product/Product.aspx?item=N82E16820148719
CPU http://www.newegg.ca/Product/Product.aspx?Item=N82E16819113348
PSU http://www.newegg.ca/Product/Product.aspx?Item=N82E16817170028
Drives  http://www.newegg.ca/Product/Product.aspx?Item=N82E16822149380     and     http://www.newegg.ca/Product/Product.aspx?Item=N82E16820211602
CPU cooler http://www.newegg.ca/Product/Product.aspx?Item=N82E16835119091
Case http://www.newegg.ca/Product/Product.aspx?Item=N82E16811112348
https://linustechtips.com/topic/112045-need-help-on-build/#findComment-1498598
