Windows Installation - Battery Charging Problem
On 10/31/2019 at 1:13 PM, Destius said:E6530
Well it uses a Ivybridge chip. So the battery if toast. Most laptop batteries your lucky to get 3 good years out of from what I have read.
The Windows issue could be a dead drive. If it were me, Id take the hard drive out and see about conecting it to another machine. They make USB to SATA adapters for this purpose. Check to see if the hard drive can be seen. If not, of it you still have issues, its probably dead. If you can read the drive, try formating it on that other machine. Then stick it in and see what happens. If the drive died, id look in to an SSD if you plan on keeping this machine. It should make it more resposive.
OR it might be time to buy a new machine. Laptop hardware doesnt age well like Desktop hardware. So Im going to say that machine is probably getting long in the tooth.
