Hi,
I have a question, i know that LLC should provide the CPU with the needed voltage, but when i use lvl 7 the CPU draws 1.41v, changing LLC to lvl 3 voltage draw drops to 1.3v, noting that no performance increases noticed only higher temps.
shouldn't the CPU draw voltage as it need? not what is being provided?
I have i7 9700 @ 4.5ghz - 4.6ghz on z390 board.
LLC: CPU Load Line Calibration
https://linustechtips.com/topic/1119147-how-does-llc-work/
11 minutes ago, Khader87 said:
Hi,
https://linustechtips.com/topic/1119147-how-does-llc-work/#findComment-13010404
2 hours ago, Khader87 said:
Hi,
Here is a better explanation using on-die readings.
https://elmorlabs.com/index.php/2019-09-05/vrm-load-line-visualized/
https://www.overclock.net/forum/27686004-post2664.html
https://www.overclock.net/forum/6-intel-motherboards/1638955-z370-z390-vrm-discussion-thread-398.html#post27860326
https://linustechtips.com/topic/1119147-how-does-llc-work/#findComment-13010653
