hey guys I'm just building a new pc and I cannot decide whether I should go with Amd or Inter
So i've got budget something around 1900Euros
And I was thinking about i9 9900K or 3700x Amd
Gpu - 2070S Gigabyte triple fan
well lemme show you the screenshot
I am buying from Alza.sk
which one of them is better ... i know that the Intel one costs more but I want to know if its worth paying the extra money
https://linustechtips.com/topic/1118199-building-new-pc-help/
It isn't worth it. The 9900k has 5% better performance in gaming which is completely unnoticeable. In non-gaming tasks, both are equal on average, they trade blows quite a lot.
The 3700x also costs significantly less, and consumes WAY less power consumption as well and isn't as hot (If any of that matters to you). It also comes with a free cooler, not that you care..but it's a decent cooler and sufficient for the 3700x.
https://linustechtips.com/topic/1118199-building-new-pc-help/#findComment-13003026
Thanks thats exactly what i thought
https://linustechtips.com/topic/1118199-building-new-pc-help/#findComment-13003030
