Hi guys im posting this because im pretty new to PC gaming and my new PC is just about 2 weeks old i had this problem since then for some reason i cant get my GPU tho use 99% or 100% of it power no matter what i do its stuck in 40 to 50 percent i have an rx580 whit a ryzen 5 2400g and 8gb RAM 3000mhz speed and a 450w psu im pretty sure it not a bottleneck because my CPU never come close to 50 percent usage and that normal i have tried many thing to make my GPU use full power but nothing helped so far i have latest AMD drivers 19.10.2 whit high performance mode in windows when i stress test my GPU for some reason it use 99% of its power like it should be but its not the same case while im gaming2019_10.27-15_58.png.cae4800bacd75fe3f8e2948e2cd80f99.png
https://linustechtips.com/topic/1117877-need-help/
Single stick of memory?
Desktop benching:
https://linustechtips.com/topic/1117877-need-help/#findComment-13000650
Btw i just checked what my usage numbers are in CSGO. CPU is like 5-15% and GPU is around 15%. Nothing wrong with that, it's "bottlenecked" by my CPU and the usage is so low because i have 24 threads. 10% usage for my CPU kinda means that 2 threads in total are fully working. This is completely standard for CSGO
https://linustechtips.com/topic/1117877-need-help/#findComment-13000746
