X370 taichi -> rosewill prism s rgb help
Go to solution Solved by Derrk,
it will be fine
Ok, so I just bought a Rosewell Prism S to replace my old DIYPC-Skyline-06. The case comes with a gypcb-80-a4 rgb fan hub that is 3-pin 5v. And my Mobo. Asrock X370 taichi has a 4 pin addressable rgb header. In the mobo manual it says it supports up to 12v, so I assume it means i can use 5v. I already know i can buy a 3 to 4 pin connector, but im worried about the "up to" 12v frying the hub (or damaging the board)
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1117724-x370-taichi-rosewill-prism-s-rgb-help/
48 minutes ago, Derrk said:
it will be fine
I second that, what your saying has no real truth to it, your fine my friend.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
