Missing Nvdia Control Panel Options
Go to solution Solved by Princess Luna,
You have a laptop with nVidia Optimus which means your RTX 2070 is just a render solution slave... This behaviour on your control panel is actually expected.
I think the only way around here is if you have the option on BIOS to completely disable the iGPU and only go with the dGPU.
I just noticed I used to have a lot more options in my control panel, like the GSync options. Now they are all gone.
I already tried making my RTX 2070 the main graphics card instead of the iGPU. But it didn't change anything. How can I fix this?
My PC specs (Lenovo Y740)
Intel 9750H, 16GB RAM and RTX2070 Max-Q
Windows 10 with latest update and the latest graphics driver.
https://linustechtips.com/topic/1117489-missing-nvdia-control-panel-options/
9 minutes ago, Br4mb0 said:
--snippet--
thats a laptop. ive had this issue before.
RTX2070 Max-Q
it probably also has intel HD graphics, that outputs to monitors and stuff, the nvidia graphics are called Mobile graphics,
beacuse their a graphics chip not a card. they dont output video, only render graphics.
it probably also has intel HD graphics, that outputs to monitors and stuff, its called Mobile graphics,
I know it's a laptop, it's right in front of me, but a laptop is still a PC. :)
And yeah I already know all of that, thx though... But I never had this issue before, that's the problem. I used to be able to change everything in the control panel. But it's been a while since I last opened it, so I don't know what I might have changed to make it act this way.
oh, sorry then.
i never had those options in my laptop. just wanted to make sure you knew that
oh, sorry then.
No worries m8, thx for the help either way. That's why I don't find any solutions I guess... But I'm 100% sure it had more options like 1 month ago.
also as a sidenote cant you just downgrade your drivers if you want those options?
theres probably some reason for the removal.
I tried reverting to older drivers, but it's the same outcome. I also disabled the iGPU and got this message when I tried to open the Nvidia Control Panel.
Personal Desktop":
Luna, the temporary Desktop:
I haven't changed anything in my BIOS though. And like I said; I remember there being more options (like 3 dropdown menu's), because I actually changed some of them when I just got my laptop a month ago. But I had not heard about Nvidia Optimus before. I'll look into it. Thanks
Damn I just checked my BIOS settings and it was on "switchable graphics". I now put it on "discrete GPU" again and it works!! I feel so dumb. Thx for the help though. Much appreciated.
