So I am truly curious and I hope that Linus or his employees may consider helping in my much needed information. So I'm taking classes at Southern New Hampshire University and I'm a some what advid gamer and I also love messing with electronics and sound devices programming I remember when I was little that I had to type in the codes to run Prince of Persia off floppy  but no I'm using the strix scar 2 not too the line like I wanted with 2070 rtx but I did chose the 1070 gtx which is fairly decent I'm running on single channel 16 GB ram haven't purchace my second ram card yet I got 1 tb ssd and in got 2 tb sshd  I got the i7 procceser I need help with knowing how to and what I can to to get the coolest temp I mean it doesn't run really that hot but I'd still like to get lower temps and customize it so I get the most out of it ,and I wasnt able to get my video uploaded for the worst PC give away but I hope I've made an good first impression on you Linus and the team with my status hope you see it and like my setup            sincerely
                  Tanner D Smith
https://linustechtips.com/topic/1117076-my-system/
                  Tanner D Smith
whats your cpu temp like at idle aswell as under load?
what cpu-cooler are you using?
how are your casefans set up?
what case are you using?
also
what I7 are you using?
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1117076-my-system/#findComment-12994515
Can you please fill in the info that's actually needed to help you? Like what current temps are?
From just this I take that you have gaming laptop. This means that your options are fairly limited. Best thing to do is to re-paste coolers of it. There are no hardware upgrades to laptops. Default fan profiles are optimized for performance over noise. Meaning that you can't improve cooling by fan control.
Cooling pads were a thing few years ago, but I don't know if they actually help.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1117076-my-system/#findComment-12994914
