Dont mind the monitor or the case i already -picked but i do need help with a case that can fit all that and has good cable management and it a good price nothing to high unless i already chose one but also need good cooling if possible this is for a friend and he is on a budget but if someone could help that would be great please and thank you.92d3aa74a8fe6ccbdf6018906a45431e.png.2ed0356dcef8218252296e045ab27fc6.png
https://linustechtips.com/topic/1115766-i-need-help-to-pick/
Gaming only PC? I recommend AMD over Intel as it is better value, also definitely get yourself a 250GB SSD at the very least for your OS.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983228
5 minutes ago, Oakmeal said:
Then what good amd processor should i choose? AMD ryzen 7 3700x?
Yeah that would be perfect. That would have been my recommendation anyways!
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983248
The 3600 is fine for pure gaming
the RX 5700 is a better value GPU, it's almost a 2070 with a bit of work
at least the p350X has mesh on top, just don't bother putting any fans in the front of that case.
You can just use a $25 120mm air cooler, 120mm AIOs are only worth it if you can't fit a proper air cooler.
Just remove the 2Tb hard drive if you don't need it, can always buy the air cooler later.
Did you already buy the case and monitor? because you can get some with the same specs for $50 less
PCPartPicker Part List: https://pcpartpicker.com/list/wdcXHB
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.79 @ OutletPC)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($159.49 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.98 @ Amazon)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($62.49 @ B&H)
Storage: Seagate Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($64.89 @ OutletPC)
Video Card: PowerColor Radeon RX 5700 8 GB RED DRAGON Video Card  ($359.99 @ Amazon)
Power Supply: be quiet! Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($80.99 @ SuperBiiz)
Total: $1052.61
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983255
Total: $1052.61
should this be a concern? Note:The Asus PRIME X570-P ATX AM4 Motherboard has an additional 4-pin ATX power connector but the be quiet! Pure Power 11 600 W 80+ Gold Certified ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it. also what kind of case?
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983259
You only need a single 8 pin for the CPU.
You only need more power if you put the 16 core CPU under Ln2, at lot of the boards have an extra 4 pin as a marketing gimmick.
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983267
Total: $1052.61
PLus the reason why i wanted to get the 1660 ti was because i have a extra one i prop should have clarified
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983268
It's fine for 1080p 144hz anyways.
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983271
1 minute ago, Oakmeal said:
Also do you know if the AMD drivers are fixed? because my experience with them was not fun lol. this was 4 months ago so
In what way on what card, on what version of windows?
I haven't had any issues from the HD 7850 and onward, used windows 7 for most of it.
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983298
you can't SLI the 1660ti, so getting an extra one is a complete waste of money.
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983307
Sorry to bother you and being annoying but would you say this case is good for all of this it's a good budget and looks clean https://pcpartpicker.com/product/w766Mp/phanteks-eclipse-p350x-atx-mid-tower-case-ph-ec350ptg_dbk and as for the Drivers Windows 10 RX 5700xt
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983308
what's your budget for everything?
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983310
No i already have the 1660 ti That's in the box that i never use and was going to give away at some point and he wants a pc and i have a gpu that pretty good and for what he needs
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983312
You had a 5700xt? I'd maybe blame windows 10, I could run games fine, but relive only worked under windows 7
however they just came out with the 19.10.1 driver and that fixed ReLive in windows 10 for me.
Did you buy the case already? If not I'd look at the MB511 and NR 600 from coolermaster for their mesh fronts
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983315
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983318
this is what i got for him dont count the gpu i put it in there for my sake for money and for compatibility and money it's weird but it's my way lol
the team group MP34 is much better for the same price as the 660P, you can get a 144hz monitor for $50 less and the 550W bitfenix whisper M is better for the same price.
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983335
7 minutes ago, Herman Mcpootis said:
team group MP34
Not that it matters really but the 660p is advertised as 1800/1800
Sequential Write 850 MB/s
https://linustechtips.com/topic/1115766-i-need-help-to-pick/#findComment-12983350
