Hey guys! Just wanted to know if there is an option on changing the msi optix stand for a more saving space one. Since the original is too big. But i serched the web and didnt find any information at all. Can i for example switch it out to a dell one? Since del is quite nice for space saving, the bottom is flat and it has the same arm. Any ideas? I just need the actual stand not a mounting arm. Any compatible ones?
https://linustechtips.com/topic/1115725-msi-monitor-stand/
Just get any Vesa Mount solution?
Or prop it up on a small shelf thing to make room under it
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12982949
Tried the second solution, didnt work out, ot becomes too raised, and the legs on the stand is too wide, therefore the raiser is just way too big.
what kind of vesa mount?
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12982963
There's too many kinds to go over just search vesa mount on ebay or amazon
Anything that clamps onto the desk is probably preferred.
https://www.amazon.com/VIVO-Monitor-Adjustable-Articulating-STAND-V001/dp/B00B21TLQU/ref=sr_1_6?keywords=Vesa+Mount&qid=1571611765&sr=8-6
https://www.amazon.com/s?k=Vesa+Mount&ref=nb_sb_noss_2
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12982973
No unfortunately not the one that clamps, since i have a strange desk, its closed on the other side, so i need a standing one
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12982979
15 minutes ago, DragonDrayce said:
Any mount that still sits on the desk is basically going to take up the same amount of space
Could always try an under desk keyboard tray, or just add a 2nd layer or even table under that desk for the keyboard/mouse.
Looks like you could use one of the clamp on arms one the right side of the desk though.
There's also those crazy sit/stand desk top things
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12983022
Thanks for recommending our stand!
Since the clamp option won't work for the desk, how about one like this?
https://www.amazon.com/VIVO-Computer-Monitor-Freestanding-STAND-V001HG/dp/B07FCRLP8X
The glass base is flat, allowing you to put things on top of it, and it doesn't take up too much space compared to most after market free-standing mounts.
https://linustechtips.com/topic/1115725-msi-monitor-stand/#findComment-12984516
