Best CPU Cooler
Go to solution Solved by csar141,
I currently have a Hyper 212 evo in my rig. From all my research, its the best cooler for the price AND the size. Dont underestimate this cooler because of its size, it works very well even with gaming (which is all i do on my PC). It is a small compact design with huge performance, which gives you more room inside your case without sacrificing much cooling capabilities at all. Obviously a larger, more expensive cooler will work better, but the performance gap between the 212 and larger coolers is fairly small, comparatively. While gaming, I have still not reached 75c even after a few hours of gaming. This is just my two cents from experience.
EDIT: This cooler is currently $35 cut down from $40 on newegg.com
nh-d14/ dark rock 2
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/111550-best-cpu-cooler/#findComment-1491110
its brown!! its solid!! its metal and plastic itssssss a brown noctua DH-D14
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/111550-best-cpu-cooler/#findComment-1491111
Project Zues:
GPU: ASUS GTX 670 Direct CU II | CPU: Intel i7 3820 @3.6 GHz | CPU Cooler: Cooler Master Hyper 212 Evo | MOBO: ASUS Sabertooth X79 | RAM: G. Skill Ripjaw Series 2x4Gb | PSU: Corsair HX 750W | Case: NZXT Phantom Full Tower
https://linustechtips.com/topic/111550-best-cpu-cooler/#findComment-1491247
if you are on a budget, get the hyper 212 evo. It is very effective for its price point
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/111550-best-cpu-cooler/#findComment-1491271
