How much UPS i need for this build?
Solved by TheNaitsyrk,
4 minutes ago, Dipypang said:I'm planning on getting APC BX1100LIMS. Is it overkill or good?
550W, should be about okay.
215W for 2070.
200W (approx if OCed) for 9900K
The rest sip power.
You should be okay.
