Hi guys kindly help me with my problem..I recently just replaced my 2600x to a 3600. At first I can go to bios and even played a bit of Cod 4. Now this happens it keep on boot lopping not going past where it says press delete to go to bios. My motherboard is the X470-i gaming from asus and has already the latest bios which is the 2801. What can I do to fix this? Thank you and God bless
https://linustechtips.com/topic/1114997-help-boot-loop-with-ryzen-3600/
Maybe it's overheating? Unstable overclock? Loose cable? Cpu not seeded properly? Idk...haha
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
I would reset CMOS first, then see if it post.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
