13 minutes ago, TylerGaming said:
so i used to be able to runs games really well, i'm currently rocking a i7-6700 and asus 1070 strix and games have seemed to not want to run as well any more its gotten pretty bad some games used to run like 100fps and now its like 50fps
maybe it's time to clean out dust and re-apply thermal paste. Hard drive or ssd for windows and or games? have you run windows update and updated graphics drivers lately?
Check if there is any unnecessary programs running in the background and clear the game's cache.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Disk partition, C disk I only give 60G. Third party software installed on other disks. If there is a problem with the system, I only need to go into PE to backup the desktop files and then redo the system. After the system is done, it only needs a simple debugging.
problem with that is that i just bought another hard drive so i haven't gotten the chance to move all the important files over and its about 1.4 tb of data, but i will try to give that a shot when i can and have the time
