So now i have this combination of components in the current pc and I post this because I cannot find the close reference cpu model with this Gfx card. Now I am using a Sapphire Rx570 4gb with a Intel Core 2 Quad Q9300 at 2.5ghz. This all with 4gb of ddr 3 1333mhz ram. Now if I run Heaven benchmark, it appears my minimum frames is 15fps on high settings, at 1240x1024 resolution. Now what is your advise on opinion on what I can do next on using this pc more effectively. I also wish someone do I video on this type of hardware mix. Thank you in advance.
https://linustechtips.com/topic/1113691-possible-cpu-bottleneck/
What kind of budget do you have for a new CPU motherboard and RAM
Primary PC:
PSU tier list
How many watts do I need?
86FPS average is good for an RX570 IMO, i get something around 30fps minimums with a Ryzen 2700 and an RX 580 8gb and average 57fps at 1080p all maxed out.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
