Hello I bought a brand new 750 watt power supply by corsair and I have a brand new motherboard from msi its the edge ac z390m I also bought new ram 16gb ddr4 from corsair it runs at 3000mhz I bought these as a result from my last build my psu gave out on me and wrecked my motherboard. I bought all these new components but now my pc wont post.
please help me find out whats wrong with it.
https://linustechtips.com/topic/1113551-pc-wont-post/
can you give more information? like whats your cpu thats one of the most important things we need to know
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1113551-pc-wont-post/#findComment-12965423
Just now, BigRusskiy said:
My CPU is a intel core i5 9600k
hmmm yeah that cpu is right for the chipset.
Just to make sure, do you have all the right cables in where they're supposed to be?
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1113551-pc-wont-post/#findComment-12965516
yes everything is correct in the system I thought at first that it was the wiring for my power switch on the case but I double checked that and I even did all the plugs to the pins all over again but that was not the issue.
https://linustechtips.com/topic/1113551-pc-wont-post/#findComment-12965602
