Hi,
my first post here.
I need advise for my new rig (new cpu,motherboard and ram) that im planning to buy at the end of november and maybe a new graphics card at the beginning of next year.
I will attach 2 files with my current rig and the upgraded one (i want to keep my storage and the psu) and  currently not planning to OC.
I only play games at 1080p on my FreeSync monitor with 72Hz.
If there is any advise you can give me, its very welcome!
Thanks!
Note :the shhd is another one as on the picture so as for the verbatim ssd (its a Vi500 S3 240 gb)
and on my current cpu is a Artic freezer 7 rev.2 installed
Current System63970480_CurrentSystem.jpg.fa9aaf0f8c13791194267c57a4ce5323.jpg
https://linustechtips.com/topic/1113382-upgrade-my-old-system/
you can get an asus RX 5700 for less right now, otherwise i don't see much of an issue.
https://linustechtips.com/topic/1113382-upgrade-my-old-system/#findComment-12964113
Forgot to mention that im from germany and the cheapest vega 56 is 217€ and the cheapest rx 5700 333€ (my budget is max 250€ for the gpu) and the vega 56 is most cases faster as the gtx 1660 ti even its drawing more power, so it is a very attractive option for me.
https://linustechtips.com/topic/1113382-upgrade-my-old-system/#findComment-12964162
Use the german pcpp site if you're buying it in germany.
https://linustechtips.com/topic/1113382-upgrade-my-old-system/#findComment-12964268
