Case: Silverstone ml07b
CPU: Ryzen 7 3700x
Cooler: Bequiet Silent wings LP or Coolermaster G100M (You guys can chose this for me since I cant decide)
GPU: Powercolor Rx 5700 xt red devil
Thermal paste: Thermalright TF8
Motherboard: Gigabyte x570 mini itx motherboard
Storage: Intel 660p 2 tb
Ram: Gskill 3000mhz 16gb x 2
I have not built or bought any parts for this PC yet, I will around black friday time. I have heard of people not getting enough airflow in the Silverstone ml07b case and I just want to make sure that when I build my PC, I will have proper airflow. Which fans will I need? Where do I put the fans? How many should I have? And how should I orient the fans? I do want my HTPC computer to be as quiet as possible without surpassing 176 degrees Fahrenheit, or 80 degrees Celsius. NOTE: This is ONLY for people that have actually built inside the Silverstone ML07B case. Or could someone link me to a forum where someone did actually have a similar issue with cooling in that case? I could use a hand.
Thank you
https://linustechtips.com/topic/1113197-small-form-factor-case-cooling/
Optimal cooling with that card would be Noctua 120x15mm LP fans(I don't think the 25s will fit with a 2.5 slot card, it would help if card makers would actually express the height in mms) and to switch out the CPU cooler for a Big Shuriken 3 with a NF-A12 slapped on in place of the default fan. Also, if you're going to have it in the horizontal position, buy a pack of the 8215k91s from the site below in order to raise the case up.
https://www.mcmaster.com/rubber-feet
  • 2 weeks later...
Does the Big Shuriken 3 cooler with the noctua fan on it have better cooling than the bequiet silent wings lp cooler? Also should I have 2 noctua fans blowing at the video card or 1 pull air in and another push it out?
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
