I bought a 2070 2 weeks ago and the card came with dead memory so i sent it back to amazon and bought a rx 5700 xt and it works fine but the fps keep droping. im 14 and dont really know anything about these cards but i can barely play i have a i9 9900kf 8gb of ram do they have anything to do with it i have to use my old 1050 ti from my old tower and it lags and looks horrible.
https://linustechtips.com/topic/1113012-help/
Depending on what games you are paying, the resolution you are playing at and your games grafics settings, fps dips might not be unusual.
In The Witcher 3 with every setting maxed out at 4k will for instance you will see fps drops for sure at that tier of gpu
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1113012-help/#findComment-12961678
4 hours ago, staticz said:
im trying to play fortnite low settings 1080p and it keeps dipping and im going to just send it back and buy a 1080 ti.
Wait a second... Please define "dipping"
What framerates are we talking about?
https://linustechtips.com/topic/1113012-help/#findComment-12962242
