I am looking at upgrading my system, current specs:
  • i5-4590
  • GTX 970
  • 8gb RAM
I want to know which components to upgrade or to add to. I mostly use my rig for gaming, but can feel it is in need of some tlc.
Looking at an i7-4790(non k), and a GTX 1070. Which one would make the biggest difference, or should I rather go another route. Any help would be appreciated.
https://linustechtips.com/topic/1112521-upgrade-advice/
What's your budget and country/region?  That will determine a what you want to spend and what things cost by you.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1112521-upgrade-advice/#findComment-12957615
Motherboard is a GA-H97N-WIFI if that helps. The budget question is difficult to answer, as I'm looking for the best (maybe cheapest) way to get more performance. I am lookin to buy 2nd hand as well. I play almost every game out there, so no specifics. I live in South Africa.
https://linustechtips.com/topic/1112521-upgrade-advice/#findComment-12957661
Go with a 1070. I wouldn't really bother shelling out the money for the CPU, you might as well save up for an entire platform upgrade.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1112521-upgrade-advice/#findComment-12957666
I would definitely say go for the GPU upgrade first. If you are looking for a good website to run different specs and see what kind of performance you would get, I would really highly recommend gpucheck.com. It will let you run different CPU and GPU sets together, to see the impact.
If you replace your CPU, you might as well replace the motherboard, and maybe the RAM, depending on whether you're still on a DDR3 motherboard or a DDR4. A gpu replacement will add some kick to your build as far as gaming goes.
https://linustechtips.com/topic/1112521-upgrade-advice/#findComment-12958732
