1 minute ago, LyndonFPSFanboy1 said:
Can you explain why my cpu is not turbo boosting itself. The cpu is always stuck at 3.6ghz no matter what i do. Clock speed stays the same in idle and even in heavy gaming.
Cpu name: Ryzen 5 2600
is ur multiplier fixed in bios? you gotta send photo of ur bios.
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948851
i think you set the clock ratio to 36? go to bios and set it to auto...
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948858
1. restart/power up the pc
2. spam Esc or F2 or Del (idk what motherboard you have so..idk which is it for you..)
   you'll be in the bios/uefi
3. go to the oc tab
4. look at the multiplier/ratio. if it's at 36,press 0 then Enter. it'll show Auto now.
5. save,exit and the pc will restart.
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948873
setting to auto shouldn't have any problem..mine is running in default speed too...i only overclock my gpu and ram...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948891
hmm..scroll around the tabs on top then..or you can take a picture from all of them then i see which 1 to enter?haha
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948918
since you're here lets enable xmp..xD
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948941
oh ya..what cooler you're using?i assumed you have a decent cooler that's why you're complaining about the boost speed..amd's max boost are just lies 3.9ghz for 2600.. it only hits it single core when there's no load...=(...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948952
enabling xmp only runs the ram at the rated speed..nothing will go wrong..
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948954
ohh...then all core 3.6ghz is normal..=x...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948967
it won't...xmp is basically motherboard asking the ram hey what speed are you rated for...then the ram reply 3000mhz..then the motherboard says ok i'll set it to 3000mhz..
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948976
Set CPU clock ratio to ''a'' for Auto if you don't want to mess with static all core overclock, Open the case, inspect your memory sticks and see what they are rated to ex: 3000mhz cl16-18-18-38, Set X.M.P profile to 1 or manual, set memory frequency to rated memory speed, set DRAM voltage to 1.35volts, and that about it.
You can also reset CMOS.... that will set everything to Auto, then set XMP profile.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
https://linustechtips.com/topic/1111494-36ghz-clock-speed/#findComment-12948991
