best wireless headphones
4 minutes ago, PurplDrank said:"for around $150...
Heres my specs if that matters at all.
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Crucial - BX500 240 GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card
Case: Fractal Design - Meshify C ATX Mid Tower Case
Power Supply: EVGA - 650 W 80+ Gold Certified Semi-modular ATX Power Supply"
Made it bigger for you this time.
lol k sure just saying the title is misleading but anyway for $150 there really isn't many great options and if your using it for gamig a headset might way to go . the arctis 7 or the cloud flights are what I would consider acceptable for the price. sounds ok as well has a decent enough mic.
