So i was upgrading my computer to a ryzen 3600 (previously was ryzen 5 2400g) and i also had 16 gb dual channel memory and when i put the new cpu in my computer refused to boot unitl i took the ram out of the second dimm slot then it booted i don't know what to do or what is causing the problem
https://linustechtips.com/topic/1111307-dual-channel-does-not-work-after-update/
Latest bios revision?
Clear CMOS and reinstall the removed stick.
Desktop benching:
What’s the cmos? Is it the battery looking thing? If so I have already done that and it has the latest bios. The motherboard is a MSI b350 gaming pro motherboard
Clear CMOS can be done with shorting pins I think, but pulling the battery and waiting for say, 5 mins should also work.
Desktop benching:
29 minutes ago, Dominus Dominorum314 said:
How do you short the pins? Also what is CMOS?
A screwdriver, or anything that's made of metal.
CMOS is the thing storing your settings. Clear it and everything (apart from bios profiles) go back to factory defaults.
Desktop benching:
Could you give me step by step instructions. Wouldn’t that be the same as just removing the battery for a couple minutes.
They are the same
do you still have the 2400G? Does putting the second stick back work again with the old CPU?
Desktop benching:
44 minutes ago, Dominus Dominorum314 said:
I accidentally broke a pin on the 2400g so I screwed up badly
Is the broken pin in the socket?
Try the removed stick in the other slot?
Desktop benching:
I didn’t see any broken pins in the socket and I did try to move sticks and only put one stick in the slot but it did not post
