5 minutes ago, KayPeters123 said:
Alot of games give you the option to cap your fps to 144 but is it better to have it uncapped if you have a 144hz monitor?
I use a freesync monitor with an NVIDEA GPU
Just watch this video:
EDIT: Or the simple answer: it depends on the game.
If you care about minimizing your input latency, then @WereCatf's post, along with the accompanying video are spot on.
The other side of the uncapped vs capped debate is whether you care about screen tearing. If your game goes above the 144hz refresh rate, then Freesync and G-Sync stop working and screen tearing will start happening again. The only competitive game I myself play is Overwatch, and I suck at the game, so I don't really care about minimizing input lag, as it's already "low enough," so I play with the game capped at 143fps via the in-game settings.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
i dont think i ever saw anything over 144hz even on unlimited. seems the monitor automatically sticks to 144? never seen any tearing either
