Help, HDD issues
Solved by Madmanchris1,
it was a problem with windows 8 ( i think). downloaded software it didnt work but then opened up disk system management ( which is extremely hard to find in win 8) found two partitions still couldn't configure them so changed them to GTP ( or something) instead of MBR, and it works fine and shows up as 2.72TB. works fine now thanks for helping.
Online quote for GTP & MBR Differences:
In most cases, you will be fine with either MBR or GPT. It is only in situation where you need to install Windows on a Mac, or when you need to have a partition bigger than 2TB, that you need to use GPT, or convert MBR to GPT. Also, for the newer model of computer that uses UEFI, it will only support GPT. ( i think that was my problem)
