Whats up everyone!
Putting together my first build and want to make sure I am on the right track. Came into the parts by luck, a couple for presents and just deals from other friends that were upgrading.
What I have right now:
Case: NZXT H500i
Board: Asus Prime Z370-A
CPU: i7-8700k
G card: EVGA 1070ti
RAM: Gskill Ripjaws DDR4-3200 (2x8GB)
Are all the above parts compatible?
Below is where I am having the most trouble:
Memory: I am planning on moving the hard drives from the PC I have now (pre-built Dell from Best Buy) will this work?
Power Supply: no idea on this, could you guys help me out and let me know which wattage I need to purchase?
Cooler: I am leaning towards the NZXT Kraken X62, will this be alright?
Sorry for all the questions folks. Getting into this the first time has seemed a bit overwhelming but I am excited to put it all together. Thank you in advance for the help!!
https://linustechtips.com/topic/1110137-first-pc-build-help/
Yes. The CPU, RAM and GPU will all function perfectly on that board.
Specs of The Battlestation:             CPU: AMD Ryzen 7 1700X             Motherboard: AORUS AX-370 Gaming 5             RAM: 16GB Corsair Vengeance DDR4 3000MHz
                         Case: NZXT H710                           Graphics: EVGA GTX 1080 SC Hybrid             Power Supply: EVGA SuperNOVA 850W Gold+
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Built 7 custom machines. Resident Tech Support Agent. Proficient in C#, JavaScript, and Sindarin Elvish. Loyal Member of House Ravenclaw. Ask me a question about hardware, and I can probably answer it.
https://linustechtips.com/topic/1110137-first-pc-build-help/#findComment-12937470
7 minutes ago, urawizard said:
Whats up everyone!
Just buy a new SSD and put your OS on that. The 500GB 660p is cheap
The kraken coolers are overpriced and I'd stick to air cooling in general, like a Scythe Fuma 2
This PSU just happens to be cheap right now
https://www.amazon.com/dp/B07H5K5L9X/?tag=pcpapi-20
This one is a bit nicer overall.
https://pcpartpicker.com/product/2HbwrH/corsair-rmx-2018-650w-80-gold-certified-fully-modular-atx-power-supply-cp-9020178-na
https://linustechtips.com/topic/1110137-first-pc-build-help/#findComment-12937472
if you're concerned about compatibility, use PCPartPicker.com. In general, the site is really useful for part lists anyway.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1110137-first-pc-build-help/#findComment-12937479
For a good quality and cheap air cooler.... can't go wrong with the trusty old Hyper 212 Evo... I had that on my 5 GHz 8700k (at 1.300 v) and it never got over 85c under synthetic benchmarks, mid 60's in games...
https://linustechtips.com/topic/1110137-first-pc-build-help/#findComment-12937480
