@LUCASBMR Based on that list, from the looks of it, no.  The AIO will need to take up one USB 2.0 header on your board.  I think that board has 2x USB 2.0 headers, but you might want to double check that.  Even if it only has one, you will be fine unless you decide to add, say a Corsair lighting node for example.  If so and you only have the one header, you can always purchase the hub later.
https://linustechtips.com/topic/1110129-nzxt-internal-usb-hub/#findComment-12937491
