ive recetly oc'ed my cpu to 4Ghz at 1.475V. I saw that the voltage can go higher up to 1.55V and kind of wanna see how much more i can get at that voltage. But I had heard that too much voltage can kill your cpu even if you're below the 80C mark. Could aomebody clarify, thanks.
CPU: AMD Ryzen 5 3600, GPU: Asus ROG Strix GTX 1070, RAM: T force rgb 16gb 3200Mhz, Mobo: Asrock B450M Pro4, Storage: Adata 128Gb SSD and Seagate Barracuda 1Tb HDD 7.2kRPM, PSU: Corsair 750W 80+ bronze,Case: Corsair 280x, Headphones: Sennheiser Momentum 2.0 Wireless, Speakers: Bose Companion Speakers
https://linustechtips.com/topic/1110109-overclocking-questions/
What CPU are you overclocking? If it's the Ryzen 3 2200g in your signature, you are already on the verge of killing your CPU with prolonged use, especially under ambient cooling. A stable, long-term overclock should not exceed 1.4v on Zen, and even that is very aggressive. I run my Ryzen 5 1600, which is on the same architecture, at 1.325v maximum for long-term usage. I actually dialed it back eventually and dropped my clock speed because I figured that 200 MHz isn't worth it.
If you're trying to kill your chip, go ahead and go past 1.5v, but otherwise dial it back.
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937236
As voltage goes up so do thermals, but thermal climb near exponentially at high voltage.
Increasing voltage to a high level can burn out a chip quicker than your heat sink can dissipate the heat or thermal protection can react. Additionally at a macro level silicon composing the chip is not perfect and there could be section of the chip that fail before others when taken to high levels.
So yes it can happen, proceed with caution when going outside or to the limit of spec.
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937239
If you're OC that 2200G you don't want to go over like 1.425V for daily use, probably want to stick below that even.
long as you're hitting 4ghz you're going to be set.
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937256
the 4 ghz is stable at 1.475
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937261
4ghz at 1.475
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937263
4 minutes ago, Moonman21 said:
4ghz at 1.475
Probably want to dial it back to whatever the lowest voltage 3900mhz is stable at.
Yours is gen 1
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937272
what do u mean by 1st gen as in the zen+ architecture
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937276
the 2200G uses Zen 1
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937280
Yours is gen 1
i got 3.9GHz at 1.36875, hows that
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937772
It's a much more manageable voltage for not much of a performance loss
https://linustechtips.com/topic/1110109-overclocking-questions/#findComment-12937781
