Hey there.
For the past month an a half I started getting kernel power errors that crash my pc on random occasions, either while gaming, watching YT videos or while in desktop.It freezes for 10-20sec and then restarts, without any blue screen. I did what I could software whise, (clean windows install, change power settings, fast boot off, update drivers, etc) to trie to solve it but it didn't help. So I think It should be a hardware problem. Either ram or motherboard maybe, since I can stress gpu and cpu fine, and because of that I also don't think is psu problems. The thing is, I'm having trouble figuring out what it is. I left the pc in a pc store to diagnose it and they said it had alot of errors in ram. After I bring it home I changed the ram from channel A to B (Dual channel) and did the test again with memtest86 bootable. The first test took about 2.30h and I had an error on stage 7. After that I repeated it and left the pc doing a test for 5 hours, and it finished it without any error... Could that indicate that the problem is with my motherboard?  I will trie to change the memory to channel A again and repeat the test to see..
I have the latest bios and most recent drivers and my windows installation is recent. Also I don't have temp problems. This problem has been so anoying.. Any help or tip would be nice. Thanks
My specs are:
- Gigabyte x370 gaming k5
- Sapphire RX 580 8gb
- Seasonic S12 II 520w
- Ryzen 2600x with artic freezer 33 esports one (No OC)
- Corsair vengeance Led 3200mhz(2x8gb)  currently at 3066mhz ( It runs stable since last bios update at 3200mhz at stock voltage but I lowered it to see if it would help)
https://linustechtips.com/topic/1109447-help-plsfaulty-memory-or-mobo/
If memtest is saying the ram has errors and it was professionally diagnosed as having bad ram, replace the ram...
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
