Hello LTT forum.
I recently made my own pc wich contains a R5 3600 + RTX 2060 NS. I'm kinda new to pc gaming etc. But my question is. If i add a extra For example gtx 710 for my 3rd monitor (connected to hdmi) will it work?
With work i mean can i put my discord on there at 1080p. Thats all. In my current Rtx 2060 i have 1 144hz monitor to Display port and a 1080p 60hz monitor to hdmi.
Greetings
Apnix
https://linustechtips.com/topic/1109004-will-2-diffirent-graphic-cards-work/
19 minutes ago, Oshino Shinobu said:
Yes, it will work.
You can't use them in SLI for games, but you can use them at the same time for different tasks.
Thanks for the reply, i was not trying to run them in SLI to begin with. But thanks alot for ypur reply again
Your RTX 2060 should support three monitors.  There will be barely any performance drop adding a 3rd monitor to the card.
A displayport - hdmi adapter / cable is cheaper than a gt710 video card or the power consumption it uses over time...
