Hey I'm trying to build a good PC for gaming, recording and editing (all in 1080p). I'm from the UK and my budget is £1300.
Parts:
Any suggestions on what to cut back on and what to spend more on?
I'm not too familiar with the AMD GPUs, is the RX 5700 XT good?
Is the CPU cooler sufficient or should I invest into a better one?
https://linustechtips.com/topic/1108449-thoughts-and-improvements-first-build/
Parts:
for 1080p gaming, editing and recording you dont need, 8 cores, but a 6 core is more where you should look,
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£301.97 @ Aria PC) stock cooler is fine.
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  (£189.38 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  (£79.98 @ Aria PC)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  (£97.97 @ CCL Computers)
Storage: Toshiba P300 3 TB 3.5" 7200RPM Internal Hard Drive  (£65.98 @ Laptops Direct)
Video Card: PowerColor Radeon RX 5700 XT 8 GB Red Dragon Video Card  (£389.99 @ Amazon UK)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  (£57.95 @ AWD-IT)
Power Supply: *Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£63.97 @ Amazon UK)
Wireless Network Adapter: Gigabyte GC-WB1733D-I PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  (£23.99 @ Amazon UK)
Total: £1271.18
Generated by PCPartPicker 2019-09-28 03:51 BST+0100
