3600X or 2600X with liquid cooler
Go to solution Solved by Princess Luna,
Get the R5 3600 instead and shift the money you'd save into a decent air cooler.
Hi! Im getting a new PC with Gigabyte RTX 2060 Gaming OC Pro cause tis the best of all RTX 2060s.
I am also getting 3200 MHz memory in case i ever upgrade from 2600X if i do get it. RIght now my choice is 3600X. Is the 2600X a better choice because of a liquid cooler?
The difference is 90 euros which means a great AIO instead of 3600X.
https://linustechtips.com/topic/1108081-3600x-or-2600x-with-liquid-cooler/
Personal Desktop":
Luna, the temporary Desktop:
I’d go for the 3600 and upgrade your cooling if need be down the line. You always want to go for more performance than flashy looks with an AIO. Maybe you can pick up a Hyper 212 or something like that for cheap to cool the 3600.
I got a ps5 and a pc pretty ballin
but why get a Hyper 212, when you can get an arctic freezer 34?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Between the two, the 3600X will perform better even with the stock Wraith Spire. I run one on my 3600X and it keeps the chip at reasonable temps.
I'd probably recommend the 3600 over the X as it's a better value, but I preferred the 3600X because of the higher stock clocks.
Main Rig: CPU: AMD Ryzen 7 5700X3D | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 500GB Crucial P3 Plus, 4TB Silicon Power UD90 | GPU: PowerColor Red Devil RX 6900 XT | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
liquid coolers only for aesthetics, no point overclocking ryzen 3000 ive been told as not worth it due to they already working so high anyway.
got 3600 anyway much better for ram overclocks.
