Blue Snowball black ICE, is there a Mini USB port replacement part?
Go to solution Solved by LAuke,
1 hour ago, Rusted said:
You can get those USB ports online, but you need some soldering skills and good soldering iron to replace that. There are some small contact pads you need to solder.
Nevemind i've taken it apart and tommorrow ill take the motherboard with the broken mini usb type b on down to the phone repair shop who can solder it off and put a new mini usb type b on for me, thanks for the help though.
I broke my mini usb port on my blue snowball ice a little while ago but i was wondering, what part i would need to buy to replace it?
Also for some reason i have a Mini USB version instead of USB B version hopefully that doesnt cause problems.
If you could link a video on how to install new part that would help too.
damn well that sucks, do you have any reccomendations of where i could send it off to? because i dont have the tools required.
