I have a core V21 and i am looking to take care of it more. I want an exhaust fan and an i will upgrade to a Scythe Scmg 5100.
What do you guys recomment to buy more for cooling except the scythe cooler? I am looking to get better cable management as well
https://linustechtips.com/topic/1107124-cooling-for-my-core-v21/
You already have a 200mm fan at the front pulling in fresh air from the front. That should be good enough for most systems unless you're running a super hot CPU/GPU (which your build does not suggest)
I'm currently running a similar configuration with my Corsair 380T (Horizontal layout, 200mm intake, 120mm air tower cooler, no exhaust fan) and system temperatures are perfect!
