Hi LTT,
I'm building a wood case for my pc, I've thaugh a lot about air flow so that it wouldn't run too hot on the wood and I think it'll be fine but there is one thing I'm not sure about : does the motherboard need a clear space behind the CPU (is it for thermal reasons or just to fit the different CPU brackets)?
https://linustechtips.com/topic/1107005-wood-pc-case-help/
43 minutes ago, Andrew 1337 said:
The cutout hole is a newer feature that makes it easier to mount third party cooling solutions. While it is not needed you do need standoffs to keep the motherboard raised off the mounting surface.
I did in fact cut out the motherboard tray of an old case and fixed it to the back plate so I still have my standoffs! Thanks for your answer I can now put everything together!
https://linustechtips.com/topic/1107005-wood-pc-case-help/#findComment-12912768
