Recommended GPU for my build
By
jsariola
in Graphics Cards
in Graphics Cards
Solved by GoldenLag,
2 minutes ago, jsariola said:Clearly budget doesn't really matter as long as I pay for what I need only. Just like 2080ti which I know the best one there but I wont be playing on 4k or 240hz 1080p monitor.
so a 2080 or 2080s then. or something.
because you should be aiming at the best at the given ammount of money you would want to spend.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
