Charger problems.
Go to solution Solved by DVA,
9 minutes ago, Windows7ge said:
If the charger gets too hot for too long that can kill it, yes. Ordinarily it wouldn't though assuming you're using it under normal operation. Sounds like a factory defect.
Most current laptops have the "brick" portion of the charger stop once the laptop is at full battery. I wonder if @NotABigGamer had it in the sun if overheating was the issue. But as for practical use, I don't believe most modern laptop chargers can overheat if at all. They get hot for sure, but not enough to kill itself (I think).
May have been a factory defect as stated or perhaps an aging issue depending on how old it is.
I had a laptop charger die for a dell laptop. I was wondering if overcharging can kill a laptop charger. Can it?
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1105002-charger-problems/
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12896779
@Windows7ge How long do you think it would take for it to overheat and break?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12896786
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12896820
I have never had it in the sun.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12896843
Its probaly a defect. The thing is like 6 years old. Its slow and i am getting rid of it i was just wondering.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12896850
I have a couple old laptops with non-original chargers. They get quite hot. Hotter than I'd like to touch. But that's not a good comparison for OPs situation.
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12897348
Thanks for all of the help.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1105002-charger-problems/#findComment-12898940
