Hi, i think i got a pretty good list of components for my new build. Critique me all you want.
  • Monitor: Asus ROG Swift PG278QR 27" (144-165hz, 1440p, g-sync)
  • CPU: Ryzen 3700x
  • GPU: ASUS GeForce RTX 2070 SUPER DUAL EVO
  • RAM: Corsair Vengeance LPX DDR4 3200MHz 16GB
  • PSU: Corsair RM Series RM750
  • SSD: Samsung 860 EVO 1TB SSD
  • MOBO: MSI B450 Gaming Pro Carbon AC
  • CASE: NZXT h500
Here are the prices (i live in denmark)
  • CPU: 2,739.00 dkk
  • GPU: 4,399.00 dkk
  • RAM: 629.00 dkk
  • PSU: 845.00 dkk
  • SSD: 1,139.00 dkk
  • MOBO: 1,103.00 dkk
  • CASE: 604.00 dkk
https://linustechtips.com/topic/1104431-finalizing-build-plan/
Why a 750W unit? Your system would only pull 350W under load. Even a 550W has tons of headroom.
Also, you can get a 5700 XT for cheaper usually and get almost the same performance as the 2070S. The saved money can go towards bigger or better SSD or more RAM
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892127
I see what you mean with the power supply, but i'm not going with an amd gpu
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892137
See about a 2080 then. They're usually close in price and slightly better.
Also, you can get a Western Digital Blue SSD and save some there to go towards a 2080
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892143
2 minutes ago, Mortrix said:
suggestions?
Fractal Design Meshify C,Cooler Master MasterBox MB511,those cases have excellent air flow.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892149
9 minutes ago, Mortrix said:
just to be sure, its the 2080 non-super right?
Yes. If you get a cheaper Psu such as the Bitfenix Formula Gold or Be Quiet Straight Power 11 Gold and a WE Blue you should be able to fit a 2080.
As for the case, the Cooler Master Silencio models offer fantastic sound dampening without sacrificing airflow
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892160
4 minutes ago, 5x5 said:
Yes. If you get a cheaper Pau such as the Bitfenix Formula Gold or Be Quiet Straight Power 11 Gold and a WE Blue you should be able to fit a 2080.
I dont know about the 2080. Its 7% performance increase, but its like 1000 dkk more expensive
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892180
Well, that's why I suggested getting a better value and equally good PSU and SSD. You'll just reallocated the funds from the overpriced EVO and overkill 750W RM to a better card
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892203
I think you are right,it's not worth it,
I would stick with the 2070 Super.
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892204
In terms of the psu. The gpu says it recommends 650w
https://linustechtips.com/topic/1104431-finalizing-build-plan/#findComment-12892267
