New to the forums, they say sharing is caring so why not…
So it begins another build, another couple of thousand dollars. Over the years I’ve built many a computer, from low end, to high end, water cooled and some that in hind sight should have been killed with fire, but never anything less than a full size system. This will be my first IXT build so it should be interesting.
The main reason for this new build is downsizing, I currently have a gaming machine as well as a everything else machine, don’t ask how this came about it just so happened like that... I’m looking to build a system that will allow me to mix work with pleasure,  a quality gaming machine small enough to lug around and powerful enough to get the job done.
So far;
Case:
I purchased a Corsair 250D earlier today to kick this build off… I like the aesthetics of this case and the fact that I don’t need to buy a new power supply.
CPU Cooling:
Corsair H100i
Power Supply:
            Corsair AX1200
SSD:
            2x OCZ Vertex 3 120GB drives for raid 0
Internal Storage:
            2x 2tb WD Red
The rest... Nothing final yet, but at this moment it will look something like this:
Motherboard: MSI Z87I Gaming AC Mini ITX Motherboard
CPU: i5 4670k
RAM: Corsair Vengeance CML16GX3M2A1600C10 16GB (2x8GB) DDR3
Graphics: MSI Radeon R9 290 Gaming 4GB
https://linustechtips.com/topic/110388-project-downsize/
-snip-
you mean ITX? mITX does not exist....
I've always found it really cool to cram as much stuff into something really small. That's why I chose ITX for my build
Anyways, do you intend to lug it around by putting it in your car or something?
And you should put your location in your profile, it helps a lot with finding good parts for your country etc...
Welcome to the forums!
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474475
That psu is way overkill for this rig. Get an AX760i or similar. That would be more than enough to power the system even with some moderately heavy oc'ing.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474496
he didn't buy that psu for this build... he already has it.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474527
I've always found it really cool to cram as much stuff into something really small. That's why I chose ITX.
Cheers for the correction, and location tip.
Yeah lug it around in the car, and squish it onto ridiculously desk spaces.
The ax1200 is from my current gaming rig, so its no additional cost to this system and has served me well. The effort and resale price wouldnt be worth the downgrade (in my opinion)
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474530
An understandable mistake as it's commonly referred to as "Mini ITX". "mITX", although slightly unnecessary, is still correct.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474551
When the prefix is abbreviated for "mini-ITX", unlike mATX, the complete abbreviation is m-ITX, with hyphen.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474589
Either way, there's only one form of ITX, any and all ways will work and be understood until another actual ITX form factor arises. Getting rustled up about it (not directed towards anyone here) is pointless. ITX is ITX.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474599
Haha, wrong, there is mini-ITX and Thin mini-ITX  ;)
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474605
I can't believe there's that many posts about a simple acronym.
We all know what he meant.
Sounds like it'll be an interesting build!
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474617
Yeah I just discovered this form factor. If a category on Newegg exists for it, it's real :P
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474623
Well then... ;) Learn something new every day!, 99% of us will be referring to the standard ITX so it's a safe assumption.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474826
There is no "standard" ITX, http://en.wikipedia.org/wiki/Mini-ITX
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
https://linustechtips.com/topic/110388-project-downsize/#findComment-1474848
The more you know.. My fault for incorrectly referencing the type of system I intent to build =(
Moving right along...
Thoughts, hints, tips, yes, no and maybes for;
CPU: i5 4670k
This will be my first personal intel build in many many years, i5 4670K seams the most logical processor for its price, but im happy to take suggestions.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1475448
I think the Corsair AX1200 will  just fit in the case levaing reduced room for cable mangment.  but you use what you have.
Linus did a review and had a ax1200i slotted in just by the look.. If its bad enough I'll sell it and get something more appropriate.. The old dslr battery is on charge, tomorrow I will test fit it and take some photos.
https://linustechtips.com/topic/110388-project-downsize/#findComment-1475542
