my gpu hasn't been running well at all, i get an average 15fps compared to the 150+fps i got when i first built my pc. i have updated the drivers and nothing is working.
my gpu clock speed is 300 and my cpu clock speed is 4620.
my specs:
i7-9700k
2080 gaming x trio
16gb ram
970evo 500gb m.2 2280
asus rog maximus xi hero
https://linustechtips.com/topic/1103868-gpu-not-running-well/
2 minutes ago, MetalJeans15571 said:
how should i test it under load?
Get HW monitor or use MS AB and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888116
Geez, stop making lazy ass posts my dude, give people some actual information other than "and what not". People can't read your mind and finish the sentence for you. You're not helping anyone, just upping your post count with nothing to show for it.
OP, MSI Afterburner is the best software for that, it comes packaged with Riva Tuner Statistics Server. Lets you run an OSD on top of most games and you can pick the stats you want. Here's my setup while running Monster Hunter World:
I set mine to the top right corner with a bunch of stats. The most important ones for this case are in the top row: GPU temp, GPU load, GPU core clock, GPU power consumption estimate (don't really need that for your use case), GPU core voltage (can't push unsafe voltages on Nvidia GPUs so you don't need that set up either). Second line has: GPU memory usage, GPU memory clocks. Then I have some CPU/RAM stats and the fps counter along with a frametime (the timing in-between each frame your GPU spits out, if this isn't reasonable smooth then you get a bunch of lag and screen tearing) graph.
If you can't bumble around the settings and get the OSD set up, I can grab some more screenshots when I get home tonight and put together a quick guide.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888137
will this fix my problem? and why did my pc work amazingly when i first built it
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888142
Nope, it doesn't fix anything. What it does do is let you know more information about your PC and how it runs in games, so you can make guesses at what's wrong and try fixing it. Like an x-ray, it doesn't fix you but it lets the doctor see what's wrong so they can figure out how to.
As for that, something in your setup probably changed or something is messing up. Seeing the temps and speed under gaming load lets us figure out if the GPU is clocking up properly and whether it's overheating or not. Can't do much till we figure that part out.
Mouse: EVGA X17
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888156
should i try and overclock my gpu ?  it says my gpu has...
power limit 3
core clock 100
memory clock 25
does that help at all?
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888166
i got that afterburner thing but i dont know how to use it
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888212
This seems to be a solid guide:
I'll be home in about an hour and 45 minutes, maybe 2 hours. Can answer any other questions then.
Mouse: EVGA X17
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12888246
33 minutes ago, MetalJeans15571 said:
i installed it now what am i looking for?
Watch the GPU clockspeed, temps, and frametimes. If your GPU gets too hot it'll throttle down and you'll drop fps. If it never clocks above idle (usually 300-500Mhz) then you probably have an issue with drivers or the card itself.
Mouse: EVGA X17
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12892099
it stays at 300 no matter what. i am trying to contact msi but they are not getting back to me and it is so hard to to contact them because they need 3 pages of info first
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12892112
good news randomly im getting 1900 MGz
https://linustechtips.com/topic/1103868-gpu-not-running-well/#findComment-12892178
