Its done this about 5 times now
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
https://linustechtips.com/topic/1103663-please-help/
remove the ATI gfx driver, get a newer or if you encounter this error with the newest one, install an older version.
And as for a reminder
HALP!!! *screenshot* Puter Problem!
Some System specs would be nice ^^
Motherboard, CPU, GFX Card, for example ?
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/1103663-please-help/#findComment-12886122
How would i go about removing them, also i don't know why but i put my specs in my sig  but its not showing below, anyway there on my profile
https://linustechtips.com/topic/1103663-please-help/#findComment-12886124
lower your memory clock speed.
https://linustechtips.com/topic/1103663-please-help/#findComment-12886127
Then a little hint where to find the specs would be nice ?
if you can't boot up at all, try booting up in safe mode to remove the drivers... how to get into safe mode:
https://www.digitalcitizen.life/4-ways-boot-safe-mode-windows-10
Main System:
https://linustechtips.com/topic/1103663-please-help/#findComment-12886131
I can boot fine, play games fine, watch YT fi... 15681857128101803363769.jpgThats the issue i had yesterday while watching YT but every other crash has been on YT and not a demanding game (GTA 5)
https://linustechtips.com/topic/1103663-please-help/#findComment-12886135
That looks more like a dying gfx card...
Main System:
https://linustechtips.com/topic/1103663-please-help/#findComment-12886141
Don't have one... i have the 3400g with its 11 vega cores. Plus at this stage its getting annoying that i have had this pc for 10 days and its already doing stuff like this.
https://linustechtips.com/topic/1103663-please-help/#findComment-12886148
Then it is maybe time for a RMA.
And you are not alone with a DOA... bought a fresh Z87 board with cpu and ram... and the board didn't want to acknowledge a cpu is installed... had to RMA the whole thing...
Main System:
https://linustechtips.com/topic/1103663-please-help/#findComment-12886154
its not that its dead it just that occasionally it runs into this exact error each time which i think is graphics related, its fine playing games and works perfectly with the exception of the blue screens
https://linustechtips.com/topic/1103663-please-help/#findComment-12886165
as :
suggested, did you try that?
Main System:
https://linustechtips.com/topic/1103663-please-help/#findComment-12886174
as :
well no but its on xmp running at the rated speed so i didnt think it was an issue but i will try later
https://linustechtips.com/topic/1103663-please-help/#findComment-12886177
running on a "faulty" XMP was the culprit in some faults the last weeks here in the message board...
Could even be damaged ram. If possible do a ram test, due to using integrated gfx it uses a part of your system ram.
Main System:
https://linustechtips.com/topic/1103663-please-help/#findComment-12886179
Yeah it has 4gb and i was thinking of giving it more actually
https://linustechtips.com/topic/1103663-please-help/#findComment-12886181
you are bluescreening cos your memory is not stable, leave XMP on but lower the rated speed down to 3000mhz. If thats stable, update the bios and try and bring it up again.
https://linustechtips.com/topic/1103663-please-help/#findComment-12886185
7 minutes ago, GoldenLag said:
so........ still not just gonna DDU and reinstall drivers?
already reinstalled the drivers... twice
https://linustechtips.com/topic/1103663-please-help/#findComment-12886191
1 minute ago, GoldenLag said:
and older driverset?
Its the first and only version
https://linustechtips.com/topic/1103663-please-help/#findComment-12886196
it could possibly be a buggy driver launch driver since the VCE is involved.
No one has reported any issues as i know a few people with an identical setup and the chipset driver is from 2019/07/05 so someone would have reported it by now if there was a direct issue
https://linustechtips.com/topic/1103663-please-help/#findComment-12886206
then its Ram CPU or mobo. and you are not the first to report issues with Ram on that mobo.
https://linustechtips.com/topic/1103663-please-help/#findComment-12886227
