Case Fan Setup Question
Solved by WoodenMarker,
1 hour ago, kr0w said:Yes, the fans that come bundled are the SP120 PE's. So do you think I should just not use those and just stick to the case fans?
Yeah, I'd stick with the stock case fans instead.
derekchan ·
1
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
play_circle_filled
Latest From ShortCircuit:
