So I'm selling my old pc and the audio was working but now it's not the front and back IO are both not working and the only audio device that comes up is my monitor because it has an audio jack in it I have wipe my windows and everything to try fix it I have realteck program installed but it doesn't pick up any thing and I made sure to check all of the cables that plug in to the motherboard and I know everything works but it just stoped working if anyone could help me it would be very appreciated.
https://linustechtips.com/topic/1103374-audio-problem/
Hi there,
I think I can help you a little here with my knowledge.
You should update your old PC with the latest sound drivers. I know it can be a little costly but to get something better in return we need to invest a little by our side too. Or you should try disabling and enabling a process for your audio driver. If this too is not working then contact TheCompuLab team as they can help you solve your problem. You can check Broward Computer services here or if you want to explore information on Google. Hope this will help you.
https://linustechtips.com/topic/1103374-audio-problem/#findComment-12889498
