Hi guys, i just assembled all the parts and everything is booting but when i exit the bios windows doesnt boot but enters again the bios.
My build is:
MOBO asus x570 tuf gaming plus
CPU ryzen 7 3700X
GPU radeon r7 just for testing the PC, tomorrow installing rx 5700 xt gygabyte
PSU corsair cx550m
HDD toshiba 1tb where is installed windows from old build
Sdd just bought and installed the 860evo 500gb
I tried to change sata Port but nothing any tips please
https://linustechtips.com/topic/1103165-build-problem/
Just now, Adrian14 said:
Whats that xD
This may be your issue:
"HDD toshiba 1tb where is installed windows from old build"
Install windows properly for the new system.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1103165-build-problem/#findComment-12881949
No, because you'll install Windows on the SSD.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1103165-build-problem/#findComment-12881960
And then i just delete windows from the HDD right?
Yes.
In the future at some point, move the files you want off the HDD to the SSD (or anywhere) then format the HDD to clean it up and make it a data drive only, moving the files you want back to it.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1103165-build-problem/#findComment-12881974
Ok thank you very much
You're welcome.  When you install Windows, verify it's on the SSD and it's that SSD you are booting from since you'll have 2 Windows drives in your machine, and one of them can cause issues if it tries to boot from it (HDD).
You're fine, no need to unplug the HDD.  Just make sure you don't boot off it in the boot manager.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1103165-build-problem/#findComment-12881984
17 minutes ago, Adrian14 said:
On the boot menu on bios it says the system cannot find a boot able system
Did you set boot priority of what drives ?
also if you want windows on the new drive I recommend making a bootable USB via windows website and clean install windows on your ssd
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1103165-build-problem/#findComment-12882004
4 minutes ago, Adrian14 said:
Yea im doing a clean install from usb, and when i try to set priority it doesnt show any boot device available
Checked that’s both Sata and power cable are plugged in correctly ?
https://linustechtips.com/topic/1103165-build-problem/#findComment-12882046
Yea because they show up on the bios
So then set that device as boot priority? Or can’t you do that
https://linustechtips.com/topic/1103165-build-problem/#findComment-12882054
15 minutes ago, Adrian14 said:
I cant do that and Dont know how to do it
You do that’s in the bios.
Find an option with ‘boot’ or similar
edir and under there will be options to set boot device
https://linustechtips.com/topic/1103165-build-problem/#findComment-12882086
@Adrian14
chexk under boot configuration
https://linustechtips.com/topic/1103165-build-problem/#findComment-12882116
