Motherboard for R5 3600
Hi everyone this is my first post,
I am seeking help to choose between the "Asus R.O.G. CROSSHAIR VI HERO"(147 eur) and the "Asus R.O.G. STRIX B450-F GAMING"(137 eur) motherboards for a ryzen 5 3600, which one would suit my gaming needs better? I usually play Forza Horizon 3, Fallout 4, Prey and Astroneer.
This is the list of parts i think i am going to buy https://it.pcpartpicker.com/list/ZQrCpG
I am also going to buy a ryzen 3-1200 wich i will use to update the bios (if needed) and then i will implement it into my parents pc in an a320 Motherboard.
cheers,
d95
cheers,
d95
Everything looks good.  I would get the Strix personally... Also you will need to flash the BIOS with the button behind your mobo and usb stick or else your CPU will not get recognized my friend.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
cheers,
Do you have a spare graphics card for your parents as well? BC If you plan to use the R1200 in their pc later, you'll need a dedicated GPU, as R1200 has no integrated graphics. Just asking.. : )
Life is really challenging. I don't always suceed: )
cheers,
d95
Get a b450 max from msi really good and ready for ryzen 3rd. gen
Btw the hero would be better becuase you can bios update it without a 1st. gen cpu and it has more features
Yes am going to buy something used even if i haven't decided yet.
Thank you for worrying!?
Thank you for the tips, i appreciate a lot?
