I would like to replace the stock fans in my PC case, the Cooler Master MB500. I am putting a 360mm radiator in the front, and I want to put ARGB static pressure fans on that radiator. The fans I'm thinking of using in the rest of the case are Deepcool CF120 fans. They seem really good for airflow (exhaust in the top and rear of the case). If anyone can tell me about some good fans to choose from, I'd really appreciate it.
https://linustechtips.com/topic/1103039-best-argb-static-pressure-fans/
If you are not on a budget on a budget, those are the best on the market.
https://www.corsair.com/eu/en/Categories/Products/Fans/RGB-%26-LED-Fans/ml-pro-rgb-config/p/CO-9050076-WW
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I looked at those and they do seem quite pricy.... anything else you can think of? Also, are these ML fans good for a radiator?
I think they are the best!
2 minutes ago, Aaralli said:
I tend to agree with that statement, but I'd still like some more options, just in case.
After them i'll go straight to Noctua...:)
EDIT: You can put Noctua, as they sell Led Rings to put them on.
