I recently started using an 8 port netgear gigabit switch to connect various pc's together for better file transfer speeds, mainly to my storage server.
Now gigabit is fast compared to wireless N, i get around 70-112MB/s when moving certain files between a client pc and server.
Can i set up my server to utilise 2 gigabit cables to increase bandwidth?
eg i have to client computers transferring files from my server and because a single gigabit line peaks out at 110 ish MB/s that would divide between the 2 computers to give 55ish MB/s. So by adding a second gigabit port i could in theory double the data rates that my server can put out to the network.
I realise that there will be limitations with the server hardware.
Also i am not an expert with networks.
PC 1 Specs (New) :
Corsair 450D | Intel 4770K | Asus Sabertooth Z97 | 16GB Corsair Vengeance @1600Mhz | Asus STRIX GTX 970 SLI | Samsung 840 EVO 250GB | 2 WD Black 500GB RAID 0 | WD Red 3TB | Corsair AX860 | Corsair H110 | 4 Corsair 140mm LED & 1 120mm Fans
PC 2 Specs (Old) :
Corsair 650D | AMD Phenom II X6 1100T | Asus Crosshair IV Formula | 4GB Corsair XMS3 @1600Mhz | Crossfire HD6970's | Asus Essence STX | OCZ Agility 3 240GB| WD Blue 250GB | WD Green 640GB | XFX850PRO | Corsair H100i
Peripherals :
BenQ 2420T | Packard Bell Viseo 220DX | Corsair K70 | Corsair M65 | Beyerdynamic DT880 Premium | Sennheiser PC360 | Bang & Olufsen Beovox X25's
https://linustechtips.com/topic/110237-lan-teamingdual-gigabit/
Yes you can use two cables to double the throughput. Look up link aggregation for whatever OS you are using.
You guys are crazy. You know you guys are self-destructive. There's a funny farm somewhere and it's got your names written all over it. But I'm gettin' outta here.
https://linustechtips.com/topic/110237-lan-teamingdual-gigabit/#findComment-1472628
Sweet, found NIC Teaming, just what i was looking for. Thanks
PC 1 Specs (New) :
PC 2 Specs (Old) :
Peripherals :
https://linustechtips.com/topic/110237-lan-teamingdual-gigabit/#findComment-1472921
